Primary clutch issues (ulmer)
Hammer70
GRIPNRIP
Niagara, Ontario.
Canada
82SS440/96VMAX/02SRX/08APE/15SRVIPER/17SIDEWINDER
2015 rtx ,135 pics, MBRP can stage 1
ulmer clutch setup primary and secondary
Osp adjuster,8DN belt secondary setup 3/3 wrap, k helix,red spring,
Primary 4 washers on heel 4 washers toe spring OPO,
143kms 9100 rpm
Clutch was cleaned and that picture is with 450kms of riding trails, railway and logging roads
Hey hammer hopefully someone with the same ulmer kit will chime in to help you out
It seems like the belt is riding really low on you primary on wot
And slipping it's pretty black at top for 450km
Yes I think so cleaned clutch in beginning of season and all moves free I'm just puzzled look at other threads and didn't make sense
another thing Hammer looking at pic it seems like the belt is high on secondary! Is it sqwealing at all?
Maybe the 8dn is too long?? just a thought!!! anyone else think that?
No belt squel. I did adjust up Before I did it his run people saying to adjust it till sequels and back it off a 1/2 turn but it doesn't squel so I didn't back off
Yes I will try that and see
Yes I thought mine looked high but wasn't squeling what wrap is on yours Marc
When stock I had different clutching so you can't really compare. I had cotc and my wrap was 3/3
I'm hoping so I thought it was to high but no belt squel is there a spec I'm going to check it tonight
Yamamarc, that pic of your belt in secondary, is it the 8JP? I'm running with 8JP and even using my adjuster mine sits a bit lower. It adjusted just enough to avoid the squeal. I have 6-1 wrap on secondary, not sure if that plays a role in getting belt to sit higher in secondary.
