phantomrider-13
Has anyone had problems with hooking up Apex Super Chargers with the Mono-Shock rear end, short track 121? If you have how did you get them to hook up? I have the transfer rod all the way adjusted out with 196 studs. I was just wondering if anyone had any suggestions.
TurboJamie
More gear I went up to a 25t and want a 26t that stops alot of the unnecessary spinning and adds to the big end.
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
my supercharger @11 psi is very fast on
hard trails but it spins in deep snow
top end in 3-4 inch fresh snow is only 110mph
stock apexes are running 100-105 same day
this was on lake gogebic 2-5 mile wot
do i have a friction problem with the stock skies/doolies
or maybe a problem with track friction
may be i need the 25 or 26 tooth gear
would overdriving the clutches do anything for me [i need advise for this modification or someone that can do this]
apex gt/skidoo drivers/fully cliped ripsaw/
196 studs/super charger @11 psi/ 10:1 wisco/
hd head bolts /stock head gasket/race pak records for 15 min /ngk ntk wide band/simons clutch kit 10400 rpm@11 psi was 11000 rpm@ 14psi
i have seen 129 on speedo or 115 on racepak on
hard pack snow
this thing just doesnt feel like it pulls very hard past 100mph
i have seen some post that guys @ 7psi are alot faster
any advise or questions please send message
or call w 618-465-5591 cell 618-781-4703
hard pack snow
LANEO
Guest
apex
I am looking to buy a s/c apex next fall Are your planning to keep your another year?
TWIN TURBO
- Aug 30, 2005
- Chicago IL.
- www.powerbygns.com
I have a Apex GT with a MPI Supercharger set on 10 psi. Was up in St Germain this weekend conditions were poor lots of snow on the lake felt like the sled was pulling a trailer but with stock gearing stock track and 192 1.450 woody's gold diggers the transfer rod set to max transfer I could stand it on the bumper from a standing start. once out alittle the track would spin .
RX!GoTurbo
Have a new in box MPI Supercharger I will sell now for dealer cost if you find a sled.
RX!GoTurbo
TurboJamie
blown apex said:my supercharger @11 psi is very fast on
hard pack snow
I pulled 164 on my speedo last week with my SC on 7lb pulleys revving 10500 rpm. Ulmers internals in the clutches. Running 25t on top. Going to run a 26t next year. You should have no probs radaring 130+ mph.
blowyam
- Jan 8, 2006
I have the same probleme with stege 1 superchage in rx1 05
y am looking for the same thing..144 woody 1.325 tranfer rond max
