The Hammer
I have had a few people ask me if the super charger will fit with reverse, Is anyone running a turbo with reverse with any problems??
Buckeye
- Lakes Region, NH
Reverse works fine with turbos. I'm not sure why it would be a problem with a supercharger. Isn't the chaincase independent of the supercharger?
LazyBastard
Maybe because the supercharger sticks out the end of the motor, is the chaincase in the way if its reverse?
I doubt it.
I doubt it.
I have a supercharger without reverse, however I do not see where it would interfer with reverse. The supercharger sets forward of the engine and the drive is ahead of the chain case. The only change on my chain case is the emergency brake bracket so the cable will not rub on the oil tank. The drive fits behind the oil tank and goes forward past the front of the engine.
P.S. The installation instructions I received with my kit shows it will work by following the install direction listed in # 23.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Reverse here and everything fits just fine.
