jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Not sure on the brand but I think its Hartman. Anyhow, I can't for the life of me get the aftermarket one to fit on the Y-pipes. I'm using a rubber mallet tapping the back of the exhaust/muffler and there is no way it will go on. Anyone have any ideas? Would it be possible to take the Y pipes off first and install them on the muffler and then put everything in together? Not sure if the Y pipes will fit through the back opening. I'll post some pics tonight.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
How do the mash gaskets look inside. If they are messed up at all it become very hard to get the pipe to slide on.
You could spend hours almost getting it on without dropping the suspension.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Well gaskets look good and I dropped the suspension. I'm going to take a y pipe out and see if the fit. Seems to be a problem with the aftermarket pipe. Just have to figure out how to get the y pipe off. Seems to me like you need to remove the header pipes??
Y pipe fits over a hook in the tunnel and needs to slide forward by removing the headers.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
You have a pic
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Okay, I got them to fit. I had to remove the header pipes, then slide the aftermarket muffler in, then put the y pipe in and slide it into the muffler. Finally went. Thanks for the help. I'll post some pictures later.
