Project: Phazer MTX "facelift"
I have noticed that some of you have found my Facebook page so I will start to write my comments in english there as well. I don´t know if I will put upp all the updates here...I have a well visited tread on a Swedish Snowmobile forum and then I will update evreything on my FB page.
I have donw some work in the garage tonight so here is some pics
This way it was with Nytro shocks ( too long)
I did mount the original shocks to get the right hight on the front
The I did place the front in such hight the the shocks is at maxlenght
I did measure some data from the originalparts so I can check against when making the new ones
The originalparts that will be chnegd to new special ones :)
I just looked at some of your Facebook pics ... you should post a few of your sled in the snow on this site. ;)!
It looks like you are planning to fabricate forward swept A-arms like the Skinz kit for the Nytro. What width are you going for?
Are you going to design a new spindle as well?
Now I have started to build the test a-arms
I have made a MDF board so I can see where the new pos. of the spindle will be
Then I will make a-arms of wood to see that all angles are OK
The lower a-arms i finnsihed
Shock mounted
The upper shockbracket will be moved forward and I will mount spearic bearings in the shock ( just ordered from Scott at OFT)
The upper a-arm is shaped around the shock
This is how it will look like when they are finnished :)
Here you can see how much forward the sopindle is moved ( the right black mark is = org.pos)
Today the uniballs from UK did arrive. I am waiting for some more stuff to arrive to be able to continue i.e. sphearic bearings for the floats from OFT that Scott has sent to me :)
Nice job so far, what size and speck are the "uniballs" or Heim joins are you using??
M16x1.5mm Male RH Rose Joint ULTRA HIGH STRENGTH for the upper A-arm
Radial Static Load Specification = 80 kN
M12 x 1.25mm Male RH Rose Joint ULTRA HIGH STRENGTH for the lower
Radial Static Load Specification =48.8 kN
Awesome, thanks. Keep up the great work.
I was looking for something other than OEM for the upper BJ and tie-rod. Will keep watching how these turn out ;)!
I have drawn the spindle in autocad and also started to modify it. The one to the left is original. When the a-arms are finnished I will measure and check everything and make the last adjustments on it then.
