Chris600
I have worked on the runningboards today
Bending the first tube
Testing
Milling away some material to get on offset on the inner tube
Nice when I can tilt the mill when I am notching the tubes
Testing on the sled
Testing on the sled
Testing
Testing on the sled
Testing on the sled
Chris600
Some more pics
Malmlof
Your Phazer is going to ROCK!!!
Very impressive work so far, keep it up.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
Can you make me some runningboards for my Nytro
Chris600
Some pics from this weekend
Fitting the new rack
Fitting the runningboard against the rack
Making the rearbrackets for the runningboard
bracket mounted
Nice to have clecos when testing
The first runningboard ready for powdercoat ( just sanblastering left)
bracket mounted
I love your work - keep them pics coming!
Chris600
Both runningboards ready for PC
Tubes for the new skid
Makin a simple "jigg" for the skid
First tube fitted
First tube fitted
Chris600
Today I have worked with the a-arms
Delrin for bushings
Busshings to one a-arm
The a-arms inplace
The upper bracket for the dampers is also moved forward
Here you can see the diffrence between the original a-arms and the new ones
Delrin for bushings
The a-arms inplace
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
looks great!
Deleted post ... saw the answer to my question in the photos.
Nice work, Chris. Some questions for you:
1. What are you using for the bushing material ... Delrin?
2. How much further forward are the spindles with the new A-arms?
Again, really nice work. The new (re-located) shock mounting bracket is a great idea BTW. I love seeing creative ideas like that come to life! Keep it up!
Chris600
Thanks!
Yes the bushings are Delrin.
I think that spindles are moved about 4" forward
Chris600
Some more pics
Made a tie rod( is that the namen?) of plastic to test
Then just to copy that into the aluminium one
And now I have to trim in the geometry to get minimum bumpsteer and changing of camber
raginyamaha
This s*** is crazy. Next you should just build a sled from scratch..... Awesome post to follow...
