Chris600
Pics from mounting the HID kit
4300K, 55W Bi Xenon with slim ballast from Humanhabits.
Complete kit with relaycables, ballasts and lamps
Very slim ballasts...good when there is not much extra space on the Phazer
Taking away the original H4
I did split the xenon lamp
The bracket for the Xenon mounted in the lamphouse
Lamps inplace
Above the batteri I did found some space to mount the ballasts
Connecting the relaycables into the H4 sockets
The just to connect to the batteri and tie up the cables
One H4 55W and one Xenon 4300K 55W
Both Xenon in place
Lamps inplace
Both Xenon in place
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
HID's are hands down the best mod I've ever put on a snowmobile. For as much night riding that I do, it is totally worth it. I can't wait to see the finished sled!
tippmannator
you TRULY have MOD-FEVER!!!! great work!
Chris600
Thanks!
Now i will have a problem due to that the homepage where I have all my pics for this tread will be closed. So I have moved my pics but they have now a different adress.
So hopefully a moderator can make a simply search and replace in all my answers to change the adress of each picture. The pictures name is the same it´s just the adress that have been changed.
tippmannator
your pictures should be good. you uploaded them to the website by the looks of it. so its as if you made a copy of the image and made TY the homepage for the copy.
Chris600
If you se unde rproperties for a picture you will se adress =
http://gbg-pop.pixbox.se/arkivet/synlig ... 804688.jpg
Chris600
Some pics from tonight
Sec. clutch to be mounted...the cover needs some cleaning
The clutchs and cover inplace
Så nu börjar vänster sidan vaNow the left side starts to be finnished
207nytro
Did the same thing to my clutch covers last week!
Love the carbon fiber work.
You should do the headlight cover too.
Does anyone know if a spare belt will fit over the clutch cover using a belt clip?
You should do the headlight cover too.Does anyone know if a spare belt will fit over the clutch cover using a belt clip?
Jeffz
- Feb 3, 2010
- Cresco, Iowa
2007 Phazer "RTX"
No, a spare belt won't fit. It will hit the side panel. I ended up getting the bag that mounts on the front of the bulkhead to put my belt in.
Chris600
The lampcover will not be in CF due to that is in soft "rubber" so the CF should not be good on that when the cover can be bent under the CF, but the windshield will be
I have also tried on several spots but haven´t find any place to keap an extra belt. So I think I also will go for the bag in the front.
Chris600
Some more pics
Revalved RTX shocks to the skid
Some more alu.parts from my friend
This will become a "homemade2 offsetaxle
Making the windshield to fit
New place for the speedometer
New bracket for the speedometer
One more layer of epoxy on the windshield
Windshield clearcoated
Skiloops inplace
Speedometer on it´s new place
Rightside cover inplace
Skiloops inplace
Chris600
I have done some job on the skid tonight
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
That looks awesome!
tippmannator
great work!!!!
