snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Dan i am a little confused about the secondary settings you listed,did you say you ran it at 90 and it ran great, and you have already tried running it at 110 degrees?? And next you may go to 100 is this right? What was the difference between 90 and 110 other than more overall shift rpms at 110 and snappier corner to corner running,and at 110 i would think it might not want to fully shift out even after a full mile run down the lake.. How did it seem to compare top speed wise between the 90 and 110 wrap? Pete
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
pete...changing your wrap does NOT change overall shift RPMS at max.....you need to change weight in primary for that.
I just felt i was hitting wall with 110 wrap,..as it went to 10,900 and 11000 right away...
the 90 wrap seem to hit abit lower at maybe 10,700 or so then goes to 11000....the higher wrap will be more consistant in all conditions...with the less wrap when you hook hard it will suck the belt abit and drop rpms..i think for radar on long hauls the lower wrap is best...higher wrap for best corner to corner short runs..
dan
dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
Any real world Radar numbers yet, with the proline Kit? Also, have you raced a Mach Z, with the kit?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
No to all the above....our track has had 4 feet of snow piled on it for the entire winter now,so i havent had my gun out once since december....also,all the mach guys either sold there sleds or wont talk to me anymore since i juimped ship!..LOL..J/K
I will post numbers or any info if i ever get it on the gun....but snow is melting fast now and calling for mild and rain this weekend...could be the beginning of end....glad i got near 800 miles on my new RTX in past couple weekends..
Dan
Dan
Racy2
- Mar 16, 2005
- Toronto, Ontario
- 2022 Sidewinder SRX LE
114.6 with the kit at 9&2 at 2,000 ft in North Bay
Racy2
- Mar 16, 2005
- Toronto, Ontario
there were 3 Mach Zs there also and the best one ran 113
SledFreak
- Feb 7, 2005
- Ontario. Canada
Did you try dropping one tooth to see what the outcome was? What was it on the dream meter?Racy2 said:114.6 with the kit at 9&2 at 2,000 ft in North Bay
thebest
i ran 122mph on gps this week-end with clutch stock and 3-3 , my friend with is attack and clutch kit 125mph ??? and my friend mack-z is really fast 132mph. we all have a hacksaw 1" and 96- 108 stud , the attack have is cam dialed, i try my ram-air and see no gain on top but i got better holeshot at all speed, i put more gaz in , and i gain some mph on top with ram-air and stock air box. yambest
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I wish i had your GPS....as it sounds abit HIGH to me.....or else you all had nice tailwind...
Dan
Dan
SledFreak
- Feb 7, 2005
- Ontario. Canada
No kidding...machzed said:I wish i had your GPS....as it sounds abit HIGH to me.....or else you all had nice tailwind...
Dan
Charged RTX
Snowbeast is correct, winding the secondary up has more effect on top end RPM than bottom. A looser secondary is of course better for top end but your helix is a lot more important.
Racy2
- Mar 16, 2005
- Toronto, Ontario
I have the 1 tooth smaller gear for the top but haven't tried it yet to see if there is any difference. Can't make up my mind
