Proline Kit + Fix Ram Air= 1 happy camper
Thanks guys, Might try the steel rivet in the tip to see if bringing the RPM down a bit helps out or not..
OR I could just leave it be because the sled is running pretty strong right now
The alum is .85g. With my RTX, I ran 10700-10800 with the steel rivet. With the alum I run 11000-11100. I also have the Excell Exhaust. I can tell you in side by side comparos with another RTX that spins 11000 and has a proline kit installed, if i run 10700-10800 he will pull me mid range by a few lengths. With it at 11000 my midrange is better that his. Get it back to 11000, thats where this sled wants to run...BBY
Sounds like the general consenus is 11,000RPM. Guess I wont mess with a good thing and leave it as is.
If it aint broke dont fix it.
"BBY" Is your Apex geared down to 23T on top??? with these RPM's??
when my chain case let go on my Attak the dealer only had a 24T,, i told to go ahead and see what it does,, well i lost a bit in the bottom but man she picks up fast and just real all them in,, so at the end of the run im still the winner all that counts for me LOLOLOL
BBY does your sled like 11000 because of the exhaust? Does your buddy that runs 11000 also run the Excell. I have not even tried 11000 because of the dyno sheets I'v seen. It sounds like you have done a lot of testing. Do you have any other mods?
With the Proline clutch kit I ran 114.6 on the gun at North Bay at 10,900. Everything else stock from manufactor. Apex ER The same top end with or without the kit. Better pull on the bottom end with the kit if you get traction.
I have a kit for sale that was installed on a GT that I parted with.. Kit has app..100miles on it will sell for $300.00 Canadian.. Both springs, weights , rivets,Helix... Will Ship anywhere.
hey bigwin....I thought you sold it?...
I rode about 250 miles this weekend with my homeade ram air kit and proline kit...with rivets in end,and it revs 11000 ontop...i wrapped mine down to 90(6/3) for abit better top end,it hits initially to about 10,800 then goes to 11000...i think ill try to wrap it to 100 next,as 110 seems to be too much for lakes....
from what i saw the ramair kit did NOT increase MY rpms whatsoever.....
i can drive right by a GT ,he gets me outa hole with ripsaw and 144 studs,while im not studded yet and have fully clipped predator,then at about 30mph i drive by him ..i would say about 3-4mph maybe faster???...
also a f7 wanted a peice of my rtx on lake o bays and i walked away from him rather handily...saw him in the mirror for awhile but then he dissappeared from it as i was ahead so far.
dan
