orangecrush
- Oct 23, 2012
- 2017 Yamaha Sidewinder LTX LE
- Lino Lakes, MN
Just wondering what the proper summer storage procedure is for the sidewinder? Gas tank full or empty? Any other recommendations. Thx
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
I do full with stabilizer. I also drain the tank before the first run and fill with fresh.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
The fuel issues are varnishing due evaporating light chains for that I use sea foam/ stabile etc and condensing water in fuel. I understand full and drain prior to first ride in fall and I am sure it works.
I usually siphon down in spring heavy sea foam then run motor then next season fill with fresh fuel. Worked for me for 30 plus years. Remember clean , oil change grease and check skid and wheel bearings & shocks.
My two cents
My two cents
trosell14843
- Nov 17, 2014
- 2005 vector
Funny, Snogoer has a 3 page article. I disagree with the oil change every year but each his own.
Sent from my SM-G935V using Tapatalk
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
As a diesel mechanic I would say Oil changing every year is good practice. The temp changes cause condensation and get in oil. I would change in fall before season.
