proper way to raise front end to work on it??
andrew1984
Woodbridge, Ontario
need to do stabilizer bar and bushings.
i dont want to damage anything and the front bumper looks inadequate for lifting???
cheers
I usually put my bike jack under the bellypan and lift like that but a sled lift would be best...I havent bought one of those yet
Hoist it by the metal bar the hood hooks over, or tip it on it's side.
floor jack with a 4 x 4 seems to work fine for me
andrew1984 said:
thanks. was worried to dent/damage the belly by lifting upwards from there. just used a piece of plywood to distribute weight.
That's all I have ever used and so far so good but I do use a couple 4x4's under the piece of plywood in case my floor jack decides to come down on it's own.
Same thing with vehicles, I never rely on just the floor jack, I always use axle stands.
I like to use a hoist with tie-downs and hook to the front bar that the hood tucks around. Other wise a floor jack with a properly cut 4x4 works.
:Rockon:
Cherry Picker (engine hoist) with a strap to the metal bar under the hood.
Just be sure to center the strap so as not to bend the bar on one side (ask me how I know) :o|
Vince
:Rockon:
I use a hoist as well, but I use it with a tie strap on the front bumper. Is the bar you mentioned stronger to lift the sled than the bumper?
ranger1 said:
:Rockon:
Yes the bar is indeed stronger...much more so than the plastic bumper.
