andrew1984
proper way to raise front end to work on it??
need to do stabilizer bar and bushings.
i dont want to damage anything and the front bumper looks inadequate for lifting???
cheers
cheers
mbarclay
I usually put my bike jack under the bellypan and lift like that but a sled lift would be best...I havent bought one of those yet
miner
- Dec 27, 2007
Hoist it by the metal bar the hood hooks over, or tip it on it's side.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
floor jack with a 4 x 4 seems to work fine for me
andrew1984
thanks. was worried to dent/damage the belly by lifting upwards from there. just used a piece of plywood to distribute weight.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
mbarclay said:I usually put my bike jack under the bellypan and lift like that but a sled lift would be best...I havent bought one of those yet
X2
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
andrew1984 said:thanks. was worried to dent/damage the belly by lifting upwards from there. just used a piece of plywood to distribute weight.
That's all I have ever used and so far so good but I do use a couple 4x4's under the piece of plywood in case my floor jack decides to come down on it's own.
Same thing with vehicles, I never rely on just the floor jack, I always use axle stands.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
I like to use a hoist with tie-downs and hook to the front bar that the hood tucks around. Other wise a floor jack with a properly cut 4x4 works.
NY_Nytro
Floor jack
Vincenthdfan
- Nov 28, 2009
- Olympia, Washington
- 2006 Apex MTX
Cherry Picker (engine hoist) with a strap to the metal bar under the hood.
Just be sure to center the strap so as not to bend the bar on one side (ask me how I know)
Vince
Vince
ranger1
I use a hoist as well, but I use it with a tie strap on the front bumper. Is the bar you mentioned stronger to lift the sled than the bumper?Apex2006 said:I like to use a hoist with tie-downs and hook to the front bar that the hood tucks around. Other wise a floor jack with a properly cut 4x4 works.
Vincenthdfan
- Nov 28, 2009
- 2006 Apex MTX
ranger1 said:I use a hoist as well, but I use it with a tie strap on the front bumper. Is the bar you mentioned stronger to lift the sled than the bumper?Apex2006 said:I like to use a hoist with tie-downs and hook to the front bar that the hood tucks around. Other wise a floor jack with a properly cut 4x4 works.
Yes the bar is indeed stronger...much more so than the plastic bumper.
