yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
Has any one put a push button start on their machine in place of the key?? If. So what did you use and were did you get the parts
Thanks!
Thanks!
Dimebag
Yeap. I got it.
I got the parts from a internet electronics shop. Nothing special about the parts, except you should get switches that can handle snow and moisture without freezing up.
One on/off switch for the ignition, and a push button switch for start.
yukon yamaha
- Jan 30, 2008
How hard was it to wire in? And could I get a pict or two put up please
Dimebag
You cut into the four wires going to the ignition switch. The thickest ones for ignition, the thinnest for start. 5 minute job.
I can take a couple pics of my setup tomorrow if you want.
yukon yamaha
- Jan 30, 2008
If you could hat would be great!
Thanks again
Thanks again
Dimebag
I couldn't sleep, so i went out in the garage to take some pics for you.
The ignition switch is the same diameter as the oem switch, so it fits in the oem location.
yukon yamaha
- Jan 30, 2008
Thanks!
Nikolai
I've had it since '09. I hate keys.
mtuyamaha
- Nov 2, 2016
- Houghton, Michigan
- 2007 Yamaha Phazer MTX 151
81' enticer 300 twin special
75' Scorpion 440 Whip
Are you using a normally open momentary switch?
HighSpeedLowDrag
