I replace my battery every other year. Only AGM battery as well. Not worth the chance of having a low or worse, dead battery
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
I went with the pep boys version of our battery on sale for $70 plus I had $20 in their rewards cash. Second season but holds a charge well, will keep all posted. The Yuasa was not available locally for me and I think was quite a bit more but I agree they are good batteries too. Key is not to charge them with more than 1.8 amps as the fiberglass mat vs lead plate design of an ASM battery will short out if your charger pumps more than 2 amps into it.Yes yuasa, sorry stupid spell check
Comatoast
- Jan 28, 2011
- Duluth MN
- 2011 Nytro XTX
WEll, ended up getting this guy.
https://www.interstatebatteries.com/products/faytx20hl
thought i was looking for this guy
https://www.interstatebatteries.com/products/cytx20hl-bs
ANyone know the difference?
Hooray!
- Aug 12, 2017
- Maine USA
First one is a traditional "wet" design w lead plates and liquid acid around them. Tip over and battery acid will tip and leak... The second one is non-spilling but does not say AGM (fiberglass matt interior no plates for vehicles that tip MSD flip). Chances are you are fine but be aware if you tip on side battery may need to be checked.WEll, ended up getting this guy.
Comatoast
- Jan 28, 2011
- Duluth MN
- 2011 Nytro XTX
The first link , the one I got is a non spilable AGM
FAYTX20HL
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
If you look at the description at the bottom of each page, they are both AGM batteries.
Hooray!
- Aug 12, 2017
- Maine USA
Great. I read "wet" quickly last night on link, my charger has a wet, gel, AGM setting, interesting it refers to an AGM as wet. AGM is what you want with all the motion, learned keep charger below 2 amps so don't use your wet charger setting. A fresh battery is always good.If you look at the description at the bottom of each page, they are both AGM batteries.
