DeepFrz
Hoping I can get pointed in the right direction here...
2011 Nytro XTX with 5200 miles. Brand new battery this season.
Every so often (happened twice to me this past weekend), I'll turn my key, gauge and fuel pump turn on, but when I go to start, the sled will begin to crank for maybe half a second and then nothing. Usually if I let go of the key, wait a few seconds, and turn it again, the sled will fire up no problem.
As I already said, the battery is brand new, connections are all good. I had this issue as well over the past few years on the old battery as well. I don't think its a moisture issue because the sled hasn't seen powder in over three years.
I'm thinking maybe the starter?
Anyone else have this issue?
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
DeepFrz
Thanks for the quick response! I'll head up to my dealer and pick one up. Is there an updated one from Yamaha (like the solid state relays)?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Also clean the connector behind the key switch. It may not look corroded but the contacts oxide causing intermittent problems like you described.
