Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
2017 Yamaha Sidewinder Rtx Le
I’m currently reinstalling my 136 monoshock skid for the first time and I was wondering if the washers should be going on the inside or the outside of the tunnel when I’m bolting the suspension and the upper shaft back in?
Also, if anyone has any tips on getting this thing bolted back in that would be great too lol.
Outside of the tunnel. Unbolt the rear transfer rod bolt on the skid and it will be much easier to line up.
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
Okay thanks! So I should unbolt the transfer rod at the back and then put the front too bolts in? Do I need to undo the limiter strap too?
Just at the back, then put the front bolts in, then put the rear shaft bolts on then the rear upper idler shaft, then set the sled on ground and push down on the rear bumper until the hole lines up to put the transfer bolt back in.
No
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
Is it normal for this bolt to not tighten in all the way. It feels like I’m at the bottom of it
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
Nvm I just put my big boy pants on and got it
The shaft is spinning. You may have to grab the shaft with Vise-grips.Is it normal for this bolt to not tighten in all the way. It feels like I’m at the bottom of it
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
Where does the washer go on the front two suspension bolts?
on the nut side.Where does the washer go on the front two suspension bolts?
Bedellsledder
- Jul 22, 2018
- New Brunswick
- 2006 Yamaha Attak
That’s what I was thinking, thank you againon the nut side.
- 7K
