Quick adjust coupler blocks
These blocks have a thin side and fat side you can just spin the rod and give that a try. I had them on the thin side and still no hook up I just pulled the rod out and took it for the same rip and skis would lift and bite.
When she hooks hard it will lay the rear suspension right on the bottom out bumpers with rear springs set on soft. Thats with the racewerx coupler set on 2 setting which is one from most transfer.
I did turn my springs up one notch. Maybe that’s why it didn’t bite as well.
