quick spool wastegate issue over boosting
jeffgilbert
Newfoundland
Canada
2019 Sidewinder BTX LE
I have a quick spool wastegate actuator on my MPI trail kit with intercooler setup and I am running a pcv-pti instead of the gems so I do not have the EABC. I am having issues with it over boosting I have almost no preload on the actuator and I am still hitting 7 psi and running lean with stock injectors maxed out. Should I just remove it and put the regular on back on with a manual boost controller?
You cant lower the boost?
I have it also. Mine boost flares also a bit. Not quite sure why. I have turned the wastegate rod and lowered the boost. (Lengthen the rod)
I have it set to almost zero preload half a turn from being loose and it's hitting about 6.8 psi
