snoboner
- Sep 17, 2006
- Eagle Point OR
- MPI Viper
I have a tether I took off my King Kat and pretty sure this will work. In the mess of wires covered by the rubber wrap is it the brown and white corded wires that are from the kill switch and if I remember right I use the brown one to connect the tether?
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
snoboner said:I have a tether I took off my King Kat and pretty sure this will work. In the mess of wires covered by the rubber wrap is it the brown and white corded wires that are from the kill switch and if I remember right I use the brown one to connect the tether?
Just make sure it is normally open with the teather off, closed with the teahter on.
Cut in to the Brown White wire (I think!) at the ignition switch.
obile
what tether is everyone running on the apex and what is the propper wiring for these? pics would help too.
snoboner
- Sep 17, 2006
- Eagle Point OR
- MPI Viper
Western Power Sports has one that mounts to the handle bar and comes with long enough wiring to reach the cluster under the cowl. Normally closed tether line. Put mine on Friday and works great
obile
any pics anyone?
obile
what wire to tie into for sure? brown white??
snoboner
- Sep 17, 2006
- Eagle Point OR
- MPI Viper
Brown wire. I cut in at the cluster that is wrapped in the heavy rubber under the bars
obile
thanks thats what i thought
