ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I had my subframe out to get Grizztrack's kit welded on and powdercoated. Of course I took it apart this spring and can't remember where anything goes while I am putting it back together.
Does anyone know where the wiring harness that connects to those boxes travels from? Right now I have the harness coming over top into the subframe. I was wondering if it was supposed to come underneath the top bar through the back. I tried looking up pictures, but no dice. If anyone can remember which way the routing of that big wire harness travels to let me know? I know it would work either way, but I just want to do it the right way.
Thanks,
p
Thanks,
p
SRXSRULE2
Which boxes were you refering to? If you want I can post pictures, mines sitting out in the garage I can go look. Let me know what area you are refering to and I'll try to help you out.
Mountaintech
He's talking about the wiring that goes to the ECU and voltage regulator.
fxnytro1050
dont know much about it but i do know it goes in behind the primary on the bottom side of the motor. not sure where it goes then. hope that helped lol
- 9K
