Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
Just out of quriousity has anyone ever attempted to put the head and cams out of a R1 into the apex to gain back the 180hp? If so is there a writeup on here on how it was done?
MDGFLHR
- Dec 13, 2016
- Windsor Maine
- 2011 Apex SE
My understanding is its a totally different motor 16 valve vs 20 valve but I could be wrong.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
yes but all the changes as fas as i know were in the top end. couldnt a guy just simply swap over everything above the pistons? Seems a simple enough way to gain 30 hp....no?
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Apex heads are basicly the same so why change heads? Sounds like the RX1 used the early R1 bike cams! Later 4 vale heads use different cams! Head is on backwards so probably will not fit! There may be aftermarket cams for the Apex! They cost big bucks.
http://ty4stroke.com/threads/apex-cams.65599/
http://ty4stroke.com/threads/yoshimura-cams.43608/
http://ty4stroke.com/threads/apex-engine-mods-big-bore.27403/
http://ty4stroke.com/threads/apex-basic-bolt-ons.29797/
If you have a large pocketbook try this!
http://www.powerbygns.com/Products.html
You want 180hp best way is add a Yamacharger and keep rpms down and hp up for probably less money!
http://www.gforcedivision.com/yamcharger
Hey big guy you forgot this one
http://ty4stroke.com/threads/new-hurricane-2011-current-180hp-apex-power-upgrade-kit.138402/
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
No I did not, I just didn't want get into that argument again! Still waiting for a ride report on that one as I like it better then the Yamacharger buy a tad!Hey big guy you forgot this one
Goody_1000
- Oct 4, 2016
- Waunakee, Wi
- 2012 Apex XTX
Thing about it is, clutches would never holdup to R1 RPMs, Apexs run 10-11k RPM, an R1 motor at peak HP is prob running around 13-13.5k. Not sure clutches are designed for those RPM...at the least the primary. I could be wrong tho.
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Power by GNS....... Unreal! It is nice to see top shelf work! Cant imagine that kind of power even in the right chassis.....Apex heads are basicly the same so why change heads? Sounds like the RX1 used the early R1 bike cams! Later 4 vale heads use different cams! Head is on backwards so probably will not fit! There may be aftermarket cams for the Apex! They cost big bucks.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Power by GNS used to have a primary gear reduction set to allow increased crankshaft RPM while maintaining the desired primary clutch efficiency RPM for that reason.Thing about it is, clutches would never holdup to R1 RPMs, Apexs run 10-11k RPM, an R1 motor at peak HP is prob running around 13-13.5k. Not sure clutches are designed for those RPM...at the least the primary. I could be wrong tho.
Darren Betker
- Jan 16, 2017
- Dryden
- apex gt
So if i had the r1 top end and the propper gear reduction.......this still wouldnt work? Just think 180hp with keeping all reliability. NA to boot. Probubly cheaper then forced induction.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Then figure out how to get the R1 ignition timing and fuel curves in the Apex ECU to accommodate the additional 2K RPM's , it takes more than just cams...
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
I think it would take much more then dropping on R1 heads and cams. If it was so easy and cheap to do there would be a ton of them built!
- 14K
