Rage r140t nytro - Aftermarket ECU install help needed
Guilt-Toy
We are putting a Aftermarket ECU on a R140t Nytro Buggy...
Need to know about the triggers and the crank sensor setup for programing into the ecu software, what the fire order is on this 3 cyl engne and need to know if there is a Wire diagram available anywhere for this buggy / engine like a stock ecu pin out?
Anyone installed a aftermarket ecu on this engine? if so i would really love to see your map file, any ECU i can download the software i just want to look how its setup to run the engine....
Any help would be appreciated, anything you have would be appreciated!
We have already built the turbo kit, want to remove the standard ecu and run aftermarket to tune it properly.
my email is d r i f t 3 3 r @ m s n . c o m
any aftermarket ecu tune files for any ecu for this engine would be greatly appreciated!!
Google ONE STOP PERFORMANCE. He has set up many of the Nytro motors with a Standalone system. Jim is the owner.
