Rage warning light.
snoway
SE.WI.
Website
www.vrbo.com
Rage has 200 miles on it.
Leaving pitstops twice yesterday ,the warning light and engine symbal came on and flashed a few times ,wife said it wouldn't go at 1st and also backfired once, before it finally took off.
The sled was warm...not the temp. warning light...
Haven't had any updates ( callbacks, tech bul.)done to this sled.
Serious?
What say you?
Any error codes?
I have had this issue on my 05 Rage, did your wife see it flash error code 84? Did she let up on throttle let it return to idle and then fine? If this is the case then it is Throttle Position Sensor. same symptons with backfiring and such. Check next time for the error code and call dealer simple adjustment.
Good Luck.
