Rapid Reaction Secondary
deshkae
Marshall, Alaska
has anyone put a Team roller secondary on thier RX short. I am thinking of doing this and want to see if anyone did. Right now I got HH's and the Black Silver spring on the secondary.
The team roller is a very heavy unit which adds to rotating mass. It also uses a really heavy duty stiff spring which works good for backshift but slows down upshift, loses efficiency & top end. I would not use it.
I dont know if turk used one or has spoke to someone who has,w/bad results,but i have one on my shorty and have run some of my best top speeds w/this unit,now i did use a diferent helix and spring from what team wanted or suggested i use,but it has ran great w/this set up,i mostly trail ride and it up shifts very quick enough so it increases your rpms thru the mid and bottom,now if anyplace it looses rpm,it would be on top,use a little less weight on primary weights or a stiffer primary spring orange silver would work good,w/stock weights w/some weight removed from tip rivet, good luck and have fun.
Roller
Hackers Yamaha in Houghton Lake,Mi runs one on there RX-1 that they race set the all time ET on grass in Mi last year.Also said it work great on asphalt too.Just going by what the owner (Rick Hacker) told me.I have not ran one my self.
