I don't think it matters which rollers.What rollers are you guys using that make the pin seat wear oblong?
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
I made longer pins from stainless bar stock, drilled a hole for the bolt to go thru....Has anyone found a way to keep the pins from turning? You still need to get them out to replace rollers so loc tight is not a good option
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
does everyone with a Tapp clutch have to heat the cover to get it off?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
No, I've never had to heat the cover to get them off on all that I have ever worked on.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
No heat to get the cover off. The heat I had to use was to get the spider off. I put the new Roller Spider Assembly in my TAPP this year. Only got 300 or so miles in it though due to the lack of winter we had in WI.
What kind of mileage are we taking before wear? Wonder if drilling and sleeving would be a good solution?I don't think it matters which rollers.
I did notice the cover on my new TAPP was EXTREMELY tight and continued to be tight after taking it off several times. I did not have this issue with my circa 2019 TAPP. It just takes a bit more effort to work it free. I could just grab on opposing slots and wiggle it freedoes everyone with a Tapp clutch have to heat the cover to get it off?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Most won't notice the wear in the pin bores until the wider rollers dont spin anymore.What kind of mileage are we taking before wear? Wonder if drilling and sleeving would be a good solution?
Over 10,000 miles before I had roller that wouldn't spin freely.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Have you noticed and differences between the pins being locked as far as performance?I made longer pins from stainless bar stock, drilled a hole for the bolt to go thru....
KnappAttack
- Feb 19, 2004
- Welch MN
I had to clearance the width of my 23's secondary to install the Hi-Torque rollers. They would not go in and spin. I'm only guessing here that the dies or casting used in production of the clutches are getting worn perhaps, but the bottoms were tapered where the rollers would not go in properly like the did in my 17.
I've got a good idea for a friction free roller that wont wear out and a pin setup that wont spin in the casting and can use the normal alum helix's. Should backshift and upshift even easier that we have now with the roller secondary.
Ok, we're all ears.I had to clearance the width of my 23's secondary to install the Hi-Torque rollers. They would not go in and spin. I'm only guessing here that the dies or casting used in production of the clutches are getting worn perhaps, but the bottoms were tapered where the rollers would not go in properly like the did in my 17.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
He said he had a good idea not a good idea he was going to tell you about!! LolOk, we're all ears.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Totally normal, Dave at tapp showed a video of warming it with a propane torch to pop it off easy. Not that every clutch will have that snug of a cover but if you do…….light warming while leaving a few bolts close to the cover makes the cover pop off and not go flying. I believe its on tommcats facebook page but video was originally posted by tapp.does everyone with a Tapp clutch have to heat the cover to get it off?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
If your good idea turns into parts send some my way for testing.I had to clearance the width of my 23's secondary to install the Hi-Torque rollers. They would not go in and spin. I'm only guessing here that the dies or casting used in production of the clutches are getting worn perhaps, but the bottoms were tapered where the rollers would not go in properly like the did in my 17.
Maybe we might get snow next year.
This may sound strange but I want some hydraulic clutches that can be computer controlled by a program that will run in a given belt temperature range all the time.
KnappAttack
- Feb 19, 2004
- Welch MN
Yes, they will need to be tested and proven for sure.
I thought of that idea on hydraulic clutches 30+ years ago now for drag racing and brought it to Dick Schmidt who was our race director for MADRAG. He also worked for Rice Lake Machine and Design at the time.... As I recall, it was not legal to run at that time, but how perfect would that be. It would also be super efficient at transmitting power where its not trying to explode the clutch outward like the weighted designs we run now. Getting it to use the energy to shift rather than exploding is where the efficiency comes from. Rotax actually has a patent on a clutch that uses oil pressure thru the crankshaft to shift the clutch on a four stroke I know. Have not seen it in use yet.
- 8K
- 7K
