Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
Have not, but both sleds were locked nearly from day 1Have you noticed and differences between the pins being locked as far as performance?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Cat had a type of hydro-matic transmission on the 1974 VIP. One year only.This may sound strange but I want some hydraulic clutches that can be computer controlled by a program that will run in a given belt temperature range all the time.
I ran into the same thing on the 24' secondary Mike.I had to clearance the width of my 23's secondary to install the Hi-Torque rollers. They would not go in and spin. I'm only guessing here that the dies or casting used in production of the clutches are getting worn perhaps, but the bottoms were tapered where the rollers would not go in properly like the did in my 17
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
How do you like the roller spider assembly?No heat to get the cover off. The heat I had to use was to get the spider off. I put the new Roller Spider Assembly in my TAPP this year. Only got 300 or so miles in it though due to the lack of winter we had in WI.
Is it still quiet? I know @KnappAttack mentioned it may be noisier so am curious if there is an advantage having the rollers over the buttons
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I only got about 300 miles on the Roller Spider, and so far I liked it. Can I tell much of a difference from the button spider? Well, not really sure as I put the Roller Spider on at the beginning of the season so I didn't get to do a back to back test to get a feel for any differences between the button and the roller. So far really good, but again, just 300 miles on it.
In terms of noise....well, not really sure either if it's louder or not at idle. The noise doesn't bother me anyway if at idle if it was a bit louder than the button style. Because I didn't do a test back to back before I made the change, it's really hard to say.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
Thanks for the insight! Might be buying a TAPP and it’s not much more money up front to get the roller spider vs button, but if you want to upgrade a button seems more expensive. Was just wondering if there were gains to be had with roller (I imagine that’s why you did it).I only got about 300 miles on the Roller Spider, and so far I liked it. Can I tell much of a difference from the button spider? Well, not really sure as I put the Roller Spider on at the beginning of the season so I didn't get to do a back to back test to get a feel for any differences between the button and the roller. So far really good, but again, just 300 miles on it.
putz21
- Apr 15, 2013
- Tomahawk, WI
Well, I had bought my new TAPP with button spider for my '23 LTX LE at the end of last season and put it on for just one short ride. To be honest, in the offseason I saw a new shiny object that was released, so I wanted to do some type of upgrade to my sled and bought the roller spider. Whether or not there are any gains to be had, not sure yet. Sure looks sexy though.
- 8K
- 7K
