Skydog
Snox49x said:So how do I set up the RB3 stutter switch. Do I just need a button and tie it to the wire ciming off of the RB3 harness?
Yea i would like to know....
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Stutter Button RB3
Some guys are connecting to brake light switch and ground with both switch map and stutter wires.
Dirt bike kill switch the right one that grounds when pushed in.
http://www.powderlites.com
what does grounding out the race fuel map and the stutter option together do?? once you let off the botton it returns back to the standard pump gas map, right?
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
- www.onestopperformance.com
aja636 said:what does grounding out the race fuel map and the stutter option together do?? once you let off the botton it returns back to the standard pump gas map, right?
yes
whats the point of the race map and stutter together?
I haven't run the sled yet since I installed the RB3
onestopjim
TY Advertiser
- Feb 22, 2006
- Howell MI
aja636 said:whats the point of the race map and stutter together?
you could put more fuel in to get it to pop but the studder is more like a engine kill and does not drop cly like our Big Stuff 3
I got the lite software and can't get it to connect to the RB3 on the sled, any suggestions?? I got the software downloaded fine and can't figure it out.
Skydog
Man not sure? I just plug mine in, and open the RB3 light software and i am in?
Skydog
Skydog
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
aja636 - get hold of the RB3 Pro Lite software, or the Pro software. The Lite version of the software are very limited and does not have the rpm hold function (limiter, stutter), the Lite Pro version and higher have the stutter funciton option in the software.
Sapling
Yep. the Lite software if very limited. It will also not allow you to adjust any fields that are above.....85 I think. The Pro software is a must!
Skydog
Yea i see that i need the Pro...
thank you Matt
thank you Matt
Mr. Pump Gas
We just got the Pro what a difference......
Skydog
Cool it is coming in the mail!!
Matt
Matt
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
How much and is it the Pro? (absolutely sure it's not the Pro Lite)?
