edgeracer1
Has anyone removed the rear bumper on there viper? I wanted to powder coat mine but after looking it over there are like 18 3/16 rivets per side and 4 or 5 heavy duty structural rivets aswell. If anyone’s done it what did you use for those heavy duty rivets
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Grinder.
edgeracer1
What about replacing them where did you get them and what type of rivet gun did you use to installGrinder.
I removed the stock bumper and replaced it with a heavy duty bumper with a hitch. I drilled out all the rivets . The new bumper came with small self tapping torx screws that worked really well..
upei93
- Apr 27, 2008
- Dalhousie, NB
I put an aftermarket bumper on...It came with bolts and nyloc nuts.
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I've had to replace rivets that shake loose on the tunnel as a matter of maintenance. You can get the rivets from your dealer. They aren't as cheap as buying in bulk, but they are the right ones and the right color. I looked and imagined pulling the bumper but that's as far as I would go! Brutal job, good luck!
