stgdz
- Mar 27, 2021
- Buffalo MN
NYTurbo
Common, gotta keep an eye on those. Yes use a button head and I put black snap caps over them. Looks good
number1kyster
I guess I should check mine. How many miles?
stgdz
- Mar 27, 2021
- Buffalo MN
3100I guess I should check mine. How many miles?
NYTurbo
Usually your tail light starts to rattle/get loose first
![](/styles/donate.gif)
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Checked mine today (3900miles) something to keep my eyes on....thanks.3100
stgdz
- Mar 27, 2021
- Buffalo MN
All four ripped off again, I used washer on the back and they still pulled through.
Can I weld the holes with a tig?
Edit.tig welder said bad idea but use a bolt and nylock instead.
I do have these but if the cooler ripps through them it's all but impossible to get them off.
Aircraft huck rivets
Are the holes in the cooler larger than the holes in the tunnel? if so, you have to fix that to make the rivets work, and/or probably go for a longer rivet for more grab. Also, if the rivets are not long enough they won't distort enough to get a good grip. I would use the method @NYTurbo mentioned, clean and simple.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I would go bolt and nylock over the rivet you picturedAll four ripped off again, I used washer on the back and they still pulled through.
REDLINE 1
I used stainless button head 10-32 x1/2” bolts with stainless washers and nylock nuts. Got them at ace hardware
REDLINE 1
I tried to post a photo but it won’t download says the file is to big couldn’t figure out how to resize
stgdz
- Mar 27, 2021
- Buffalo MN
I did m6 cap bolts, washers on both sides, blue loctite on the thread, and a nyloc.I used stainless button head 10-32 x1/2” bolts with stainless washers and nylock nuts. Got them at ace hardware
Torqued to about 150in-lbs
REDLINE 1
