snomanz600
- Jan 12, 2012
Hey guys, first off this is my first time posting and just want to say this site kicks *ss!!! If it wasn't for this site I'm not sure if I would have bought my Nytro. My question is does anyone know the inner and outer diameter of the rear idler wheels on a 08 rtx? I tried exhausting the search button before posting with zero luck. Thanks in advance.
yox185
178mm outside diameter. Has a 6004 bearing, which has a inside of 20mm and an outside of 42mm.
snomanz600
- Jan 12, 2012
Thank you so much for the fast reply!
mx1500
if i bought a 144 track, and used a 8inch wheel kit. would it fit in my 136 skid?
Nine2Nine
mx1500 said:if i bought a 144 track, and used a 8inch wheel kit. would it fit in my 136 skid?
If you talking about just adding the 8" rear wheel kit, you would not be able to go to 144" Your 136" would still fit. Does someone make an 8" Kit for the Nytro other than OFT that works with only their ext's ?
