fldodge
a friend of mine picked up an 08 apex ltx gt 40aniv. with 1600 mi. on it in excellent shape except the rear harness going to the shock was torn in two he replaced it but now he can not get the shock mode to come up on the speedo. screen anyone have any idea`s as to what is going on ? the only time the shock comes up on the screen is when the key is first turned on then it goes to your fuel gauge and will not come back even when he steps though the different screens with the mode button. what gives thanks in advance
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
check the shock it self the switch on the shock might have to be changed
Essarex
the sled won't "see" the ohlins if the wiring is still open, which I assume is the case here. any force strong enought o break the wire or connector, surely pulled the leads out of the on-shock solenoid.
ramblnman
like darv said, probably the adjuster switch wires on the shock broken inside. had to replace mine this year. i paid around 84.00 from bruce at pioneer performance.make sure you route the wires correctly or you will tear them again.always de-ice the suspension around the shock before riding is the key to longevity for these shocks wires.
Snowmobileaddict
Below are some resources for replacing the solenoid.
Ohlins Part #20014-05 (order it through any Ohlins service facility - no need to pay for the marked up Yamaha part number)
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
Snowmobileaddict said:Below are some resources for replacing the solenoid.
Above and beyond!
This type of assistance is what makes this site, and the group of guys helping each other out, one of my favorites!
Cheers!
unclearpine
- 11K
