Rear skid issue.
Gannoochi
Miss
Canada
14 viper ltx
Doing some pre season maintenance and can't line up this track . Got the sag the same on both sides and adjustment bolts are pretty even both sides but the track is over to the clutch side and upper idler rubs on the inner track nubs . Anyone else have this issue? 2014 viper ltx.
Sent from my SM-G930W8 using Tapatalk
Do very small adjustments. Mine took some time to do.
Sent from my SCH-R970 using Tapatalk
I tighten the bolts evenly to get tension correct and run it. Gave up on alignment years ago on this sled. Dont lose any sleep at over it.
It looks like my drive cogs aren't centered on the drive shaft. The track is tighter to the clutch side at the front of the tunnel.
Thanks guys for the replys. Thanks for the link cannondale , I think that's the problem I'm having so it seems kind of common on these sleds. I've always ridden arctic cat and skidoo but thought yamaha was far superior in quality. I guess I was wrong.
Its a Cat Chassis. But yes this issue bothers me also. Has to scrub speed. My track doesnt roll on stand like my Phazer does.
