Rear suspention adjustment
yamahas
Staff member
Tech Advisor
Winnipeg, Manitoba
Canada
2009 Phazer RTX
Today i noticed that my 09 RTX's rear suspention is very soft... When i put my weight on it its acctualy bottoms out. Can anyone help me out with the adjustment i need to make to fix this problem?
Alright so i made them stiffer and same problem...
The spring is just there to mainly hold the sled up, the Shock does most of the work. I know I can easily bottom my MTX if I sit on the grab bar, hell, it will actually lift the skis of the ground if I do this. Take it for a spin and see if you actually bottom it while riding and play with the shock setting to "cure" it if you do. Your springs are the stiffest out of the factory springs but there is a "race kit" which has stiffer springs yet.
The problem is that it won't come back up after.
It wont come back up at all?Have you checked for broken pieces?Something binding?
