Jean-Francois Maillet
- Jan 17, 2015
- nytro xtx 09
Hi!
I need to change my Rear Track Shock on my Nytro XTX 2009 because the last one exploded... Do you know if I have to remove the pre-load(the cam) from the rear spring or it's ok if I just hold it with "straps" before removing it?
thank
thank
Remove the spring preload, should be able to just unhook them... it will help a ton.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I've found disconnecting the limit strap will also make things easier.
- Jan 17, 2015
- nytro xtx 09
good ! thank you
- 6K
