phazerdrew
Anyone with a stock length 121 phazer run just the 2 center wheels? I was out working on the sled and noticed how close the rears are to just falling off the track, the track is adjusted properly.. just wondering if its been done and what needs to be done on mine to do it
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
you would need some sort of kit as the axle would be way to long - personally i run 4 wheels as I have had the stock yamaha wheels come off in the past and i dont want to bend my rails with the track hitting the adjusters.
phazerdrew
just trying to get some ideas, i would eventually like to do the AC 128in track
snippe
I bought my 2 wheel axle at http://www.carbonsled.com/2_wheel_axles.htm.phazerdrew said:Anyone with a stock length 121 phazer run just the 2 center wheels? I was out working on the sled and noticed how close the rears are to just falling off the track, the track is adjusted properly.. just wondering if its been done and what needs to be done on mine to do it
phazerdrew
thanks man thats exactly what im looking to do
Jeremy
Woolyviper has the best idea, I'm in his boat !!! The same setup that I run !!!
buddhahead
- Mar 21, 2008
- Mid-Michigan
- www.shawwinkler.com
I like the look of the 2 wheel setup and if you have lots of snow, I dont think it will be a problem. I'm like wooley and jeremy, I run the 4 wheel setup
woolyviper
- Mar 24, 2006
- hibbing,mn
i ran the two wheel setup one time, one outside and one inside, that's why i run 4 now...
- 7K
