mikechm3
- Oct 16, 2015
- 2015 Yamaha STX-DX
- Brights Grove
What model of lowrance is this, Elite 4 ? Does it have a direct line to the battery? Looks like what i'm after. What did you use to mount it.
Thanks.
Thanks.
Yes, that is the Lowrance Elite 4 HD. The mapping software is from VVmapping. I have been working with them for several years. All of Michigan, Wisconsin, Indiana and alot of Minnesota are charted plus nearly all Forest access routes. I used a Ram mount 1" ball mount. On the bar risor I built an alum plate the slid inside the risor and through bolted. So no holes were drilled into the machine anywhere. The wiring went to the accy plug and is fused, only on when the key is on.
stormin norman
- Dec 11, 2007
- Southern, MN
- 2014 Yamaha Viper LTX LE
2000 Yamaha SRX 700
1999 Yamaha V max 500
1992 Yamaha V max 4
1984 Yamaha Phazer
Could you show a photo of how you made the mount? Thanks
The sled is now 200 miles away. But basically the 1" ball mount has a 2" diameter mount. The handlebar extension is hollow so I slid in a 2" wide alum plate inside the extension then through bolted. Basically the extension is sandwiched in between the ram mount and alum plate
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Nice work looks great
