Murse
- Sep 7, 2012
- Cornwall, Ontario, Canada
- 2011 Yamaha Apex Std Red
Just purchased cold weather relay (Red top) 3 weeks ago tried it yesterday at -31 Celsius and she started right up.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Mine will start at that temp with the old relay. Just hasn't got any moisture in it yet.
Deedge11
- Nov 23, 2014
- 2006 Yamaha Apex
Where did you get the Red Relay from?
Murse
- Sep 7, 2012
Dealer
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
The old relays are OEM # 8FP-81950-01-00....and the new 'red' is 8GN-81950-00, correct?!!
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
8GN-81950-00 That is the only relay available now.
yamahahaapex
where is that relay located again on the new apexs? I had a problem with mine last year and pulled it but cant remember which out of the four it is...
Grimm
-31 Celcius? Where were you?
Murse
- Sep 7, 2012
Cold snap last year around home that was with wind chill so as far as the machine is concerned-25c
sx7001
- Jun 28, 2003
- Sidewinder
One on the very left or outboard.
Winderallday!
If you want to make sure you have the correct relay by checking wire colors...........
Red/Green
Red/Blue
Red/White
Blue/Red
Find those and you should be golden.
Cheers
Red/Green
Red/Blue
Red/White
Blue/Red
Cheers
Grimm
My bad, I didn't see that you posted this last year...I thought you meant this season.Cold snap last year around home that was with wind chill so as far as the machine is concerned-25c
