Yamaha Attak only runs when cranking, fuel pump power turns off in run key position
benmcmahon22
Age
39
Nottingham NH
2006 Yamaha Attak
2006 Yamaha Attak
Odd electrical issue, hoping someone has insight.
Diagnosis:
1) Fuel pump has power at the pump when cranking ONLY, and engine runs only while cranking. When key is released into run position, power to fuel pump turns off. Ignition remains on at dash, lights etc.
2) Consistent with (1), I do not get the fuel pump prime when ignition is switch from off to run (as is typical before you start cranking).
3) Fuel pump relay is good (obviously due to (1)), ignition switch is good (checked for signals at ECU). Signal coming out of ECU to fuel pump relay behaves as described in (1), i.e. no power to fuel pump relay in run position, but power applied when cranking.
Is there any sensor that would be causing the ECU to cut power as described? No codes are shown on the dash.
maim
Staff member
Moderator
sudbury on
Canada
2016 apex xtx
x3 bad ign switch.
hibshman25
Vendor
Age
39
Lebanon, PA 17042
2017 sidewinder ltx dx
2018 snoscoot
Any chance you swapped the starter relay and this started to happen?
