MBOKMAN
- Sep 27, 2021
- SOUTHWESTERN NEW YORK
- 2023 VR1 BOOST, 2022 XCR 850
2018 Thundercat with TD Jukebox header tunes
Does the speedo need recalibration when changing gears on these 998's?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I don’t think so, the speed sensor is on the drive axle so as long as you don’t change the drivers you should be good
MBOKMAN
- Sep 27, 2021
Thanks Rtbo. That's good to know.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
No it does not require
sideshowBob
Your speedo would only be affected by changing either the pitch or number of teeth on the driveshaft track drivers as it would have the same effect as changing tire diameter on a car.Does the speedo need recalibration when changing gears on these 998's?
