Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
So, as the season winds down, is there any reason to wait till fall to change fluids and regular maintenance? Or do you prefer to do it now?
The only thing I don't like is tensioning the track until I'm ready to ride. Too much stretching going on.
i do all of mine over the summer so all i have to do is freshen the gas and ride once the season hits.
Fleecer
- Jun 13, 2014
- 2019 SRX
Service in the spring so contaminants in oil don't settle in engine. In case you need parts, you have all summer to wait in case they are backordered.
I usually leave the fuel tank dry upon storage, but this year I may fill it to take advantage of the savings. Currently gas is only $4.39 per gallon and they predict $8.00 by summer.
Go Brandon!!
Go Brandon!!
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Best to clean up good before storage, , clean clutches and do your inspection while you clean, make a maintenance list of anything that needs attention, get your parts and fluids and then do the work at your convenience.. I put a tender on the battery and treat the sled with a good finish on plastic, treat the seat material and I make sure everything gets grease .. I keep winter fuel 1/4 tank in sled and start it and run it every other month for a few minutes just to keep things in good working order .. When season rolls around I drain old gas and in goes new winter fuel right before I ride.. Always works for me and more importantly like it should….
And don’t forget to do your shocks and whole suspension. Spring is best time to do it. Then in fall do extra fun things.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I usually start my preseason maintenance in September, October the latest.
Time to rethink that strategy that I have been using for decades, whereas so much of what we need is imported, and we all know how that has been working since Covid!
And yes to shock rebuilds on both sleds for next season!
Simplespeed
- Jan 8, 2022
Yes as part of a Good Maintenance program shocks are often overlooked .. This also gives the sled owner opportunity to adjust the shock valuing to their preference ….
RAMSOMAIR
Gas prices are a global thing, very little to do with current government. Can we ever not bring politics into our pleasure?Service in the spring so contaminants in oil don't settle in engine. In case you need parts, you have all summer to wait in case they are backordered.
Go Brandon!!
Doc Harley
- Oct 17, 2016
- Here & there
Yep....she's starting to ride like a caddy.
f16_fixr
- Feb 15, 2015
- Stoughton, WI
- '18 Sidewinder LTX DX
How often should the shocks be re-done? I have an '18 winder LTX-DX so have the basic gas shocks on mine still. Thinking about upgrading but after having to spend $11K on my house last summer, shocks aren't in my budget just yet... Don't put as many miles on her as some of you might but currently sitting at right around 3K.Yes as part of a Good Maintenance program shocks are often overlooked .. This also gives the sled owner opportunity to adjust the shock valuing to their preference ….
sab2022
AND in addition to shocks/suspension, any comments on storing the winder in the air on a sled lift??
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I always store mine lifted.AND in addition to shocks/suspension, any comments on storing the winder in the air on a sled lift??
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
X2 on both my sleds.. Gets them off the concrete garage floor..I always store mine lifted.
I pull my entire skid out also.. Summer cleaning and inspections/bearing re grease
RobX-1
- Coldwater, OH
Steve (@cannondale27) can confirm this but generally you should have the shocks serviced every 2000-2500 miles as the internal shock oil begins to break down and/or the nitrogen level generally needs to be recharged.How often should the shocks be re-done?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Too early to start that stuff!
