allyammies
Long story short version, last year had a bad gear broke tab off chaincase cover. JB welded put new gear in ran the rest of year but a little leak. This ordered new outer cover. Trying to get cover back on and cannot get back in. Is there something I forgot to do differently from last year? Thought I just put it back on and everything lined up.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
The hardest part for me is lining up the 2 rods for the reverse gear. Other than that just take your time and make sure the bottom is down far enough.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Make sure those 2 rods for reverse gear are seated all the way in, tap them in.
Did you get it to go? The pins on the reverse are as Denny said that parts that would hold you back.
allyammies
No I have not had a chance yet.
