r6chiro
Hi guys,
I'm trying to change the jackshaft bearing as per the instructions on the site. I've got the four bolts out of the cover and the coller off the bearing but the cover doesn't seem to want to give. Do you have to give it a pounding, or am I missing something?
thanks
thanks
maxdlx
There is one small bolt in the center of the cover that is often overlooked. That is if my memory serves me right. it is like a 8 mm or 10 mm bolt
r6chiro
Thanks, got that. It seems that bearing behind collar doesn't want to slide off shaft completely. i can move the entire cover back and fourth on shaft about 2"
maxdlx
On mine I used a rubber mallet and tapped it some and it came once i got it that far. Maxdlx
r6chiro
Thanks, Ill try that.
tkuss
Yea I had trouble getting mine off as well. Just make sure all the bolts that need to out, are out. And then a rubber mallet helps the process.
r6chiro
Thanks guys got it off. Trying to remove gear on driveshaft. It's not reverse threaded or anything wierd right? I'll look in other posts as well.
mork110
If you have reverse it will be the reverse fork hanging up on the gear collar you will have to reach behind the cover with your finger and get the reverse fork off the collar
r6chiro
Got it all apart. Will work on removing jackshaft bearing in the morning. Thanks for all the advice.
