RDCrazy
- Nov 27, 2014
- Northern Illinois
- Nytro xtx
I was wondering if I remove the coupling blocks what effect will this have on the sled will it damage the wheels, will it rub, will it make the suspension more cushy!!!
What effect will it have? Will it tear up rear suspension. Has anyone one done this?
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
I have had mine out for 3500 miles and counting and it has not done any damage to my sled. If you like to pull wheelies this is the way to do it. Some might argue that it will make the sled push in corners but in my opinion as long as you are not accelerating in the corner it doesn't make any difference. I say take them out and try it, worst case scenario you put them back in and it cost you nothing.
SGVIPER
- Dec 15, 2019
- Ontarii
- 2015 Sr viper
Did you remove everything or just the blocks off the bar?I have had mine out for 3500 miles and counting and it has not done any damage to my sled. If you like to pull wheelies this is the way to do it. Some might argue that it will make the sled push in corners but in my opinion as long as you are not accelerating in the corner it doesn't make any difference. I say take them out and try it, worst case scenario you put them back in and it cost you nothing.
ltxbill
- Oct 10, 2017
- onalaska
- 2015 yamaha sr viper ltx se 1998 srx 600
I have a ltx, took the blocks out made a huge difference in weight transfer . Hooks up now, where before it would just spin.
SeX Viper
- Mar 22, 2017
- Minnetonka, MN
- 2002 SX Viper
2014 SR Viper RTX
I removed the blocks and the bar.
