CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
- 2009 Yamaha Apex GT
I have Ulmer airbox, PCV, ignition controler, and HC Drag n Fly. WOT RPM is a quick 10,800-900. Works well when driven aggressively.
If I am growing old of anything it is the hard engagement, and bush trail manners. I think going back to the stock clutch kit will help smooth out.
Do you think I'll give up top end speed performance ? Or just the hole shot, where I believe the hard engagement, is in fact belt squeeze at a higher launch rpm ?
Do anyone think that my other mods would takle the RPMs too high with a stock kit on. ?
yooper1
Try the orange-pink-orange spring. Just added it and it helps with all of that! Under $20.00 at the dealer.
DAGE
- Nov 8, 2005
- where the snows at
- Other
- 06 Attak
are you running the HC black spring?
if you are do what yooper1 suggested, I found the HC spring to be really harsh on engagement and the OPO to be really smooth but you might have to adjust your weights slightly
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Yes Iam running the HC black. Thanks guys I will try the OPO.
So you'al believe there is enough benefit from the kit to leave it on, but just fine tune it ?
yooper1
YES, try it. It's cheap and you'll like the Torque.
DAGE
- Nov 8, 2005
- Other
- 06 Attak
get the long OPO spring, I bought the short one and my engagement is a little too low, roughly 2900-3000 rpm
yooper1
i REALLY like the low engagement. Just saying.
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Is this a Yamaha spring I can just order from dealership ? Or do I go back to Heelcklicker ?
yooper1
Yamaha Part number 90501-605J5-00
CANAM 4 Stroker
- Oct 26, 2005
- www.klim.com
Thank you very much.
