deerlodge
How do I remove the jackshaft bearing, my bearing blew apart and the outsideof the bearing is stuck. I tried heating it, but that didnt work. Any suggestions?
Rich
Rich
Travis Moore
Wow-that sucks. Maybe some pictures would help us.
deerlodge
LazyBastard
Think you can get to the inside with a chisel? If not, use a dremel to grind it.
deerlodge
i pulled the gas tank off and there is no way to fit a chisel in there, I might try the dremel
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
There is a tool that is similar to a dent puller where you can invert the end pullers for removal of this bearing race. We have one at work! Check it out on the web
black john
bearing
a dremal with a cuting wheel cut two slots one on each side inside the race and it will fall out. bu take your time. that bearing fit,s tite in there even when new. once you socore it real well just tap it with a hammer and chizel and it will brake on the scored line,s as the race is very hard.
black john
bearing
remove the drive shaft 1st . this will give you more room to work.
deerlodge
thanks for the help guys, I will try to cut it out with a dremel tomorrow
srxpert
puller
A reverse bearing puller should pull it out.
rx1mtn
I'm going thru almost the same thing, only I'm changing mine before it goes bad. I took out the cross shaft and used a long chisel like tool to remove the bearing. BUT, now that I've got it apart, I need the upgraded part numbers. Anyone have the numbers?
deerlodge
there was a bushing on the shaft that was chewed up, its maybe 2 inches long and its split down the middle. does anyone know what thats called so I can get another
black john
coller
thats a coller out of the 03 just get the 04 parts as an up grade. coller,lock nut and washers. now is the time to do this. 04-05 -06 use these parts
LazyBastard
You do NOT need the washers. The collar and nut are sufficient. You can use the original 03 washers. Different part numbers, same thickness, no difference.
Bob Miller
- Apr 19, 2003
- New Milford CT
Re: puller
Yeah! That's what I was talking about.
srxpert said:A reverse bearing puller should pull it out.
