Wingwong
- Mar 20, 2018
Hello ALL Yami people,
I saw Rocker Dan's Belly Pan Protector from Barn of Parts. I want to install the same. I have never taken the Primary Clutch off. So, I need help with the steps.
First, I need a clutch removal tool. My Yamaha dealership said I could use theirs anytime, so that's excellent service. Thank you Urban Sport in Arnprior, Ontario.
If anyone can help, it is greatly appreciated.
Couple questions,
1. Will it come off in 1 full piece with the clutch puller?
2.To re-install it, will I need to check offset or any other measurements for belt alignment purposes?
3. when re-installing, do I need a specific torque setting?
Maybe it is way easier than I think. But HELP is needed.
Thank you in advance.
Couple questions,
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
1. It will come off in one piece.
2. No
3. Torque to 108 ft/lbs, then loosen and retorque to 45 ft/lbs is what I believe the manual says. I torque mine to 60 ft/lbs.
2. No
Also do not spin the clutch clockwise (opposite of it's normal direction) if at all possible. The timing chain tension can slack and jump/skip if going in that direction.
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
I just installed the BOP bellypan protector in my 18 Winder, and did NOT remove the primary.
BOP has a handy template (see his website/instruction sheet) to use on the outside of the plastic panel for locating the center of the 2 bolt holes.
Worked like a charm.
Cheers.
Cheers.
Wingwong
- Mar 20, 2018
Cheers.
Ok
Did you take shock off?
I have LTX with gas canister on side seems to be in the way
DMCTurbo
- Nov 12, 2005
I installed the BOP protector without taking anything off.
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I did the same. Took nothing apart. As another member here did, in the spots where I couldn't get the drill positioned correctly I marked everything with the template and heated up a finish nail with a torch and then pushed it thru. Cleaned any melted plastic around the hole with razor knife then I took the correct size drill bit for the bolts and spun them with my fingers to finish it clean. Took a matter of minutes.
Wingwong
- Mar 20, 2018
Thank you guys
I just finished
I didn’t remove the clutch or the shock!
Used a nail, lighter, and a screw for the most part.
Some much help guys thanks thanks thanks
I just finished
Wingwong
- Mar 20, 2018
Thank you1. It will come off in one piece.
2. No
SAB1
- Mar 1, 2011
- Tuftonboro NH
2010 Vector GT
2006 Apex
Glad it worked out. Thank you for your help with the rivnut install. One sled done one to go.
Winderallday!
- Dec 4, 2007
- SW, Ontario
Ok
I had my sled on a stand and just removed the shock to get proper drill access, fairly straight forward. Several ways to skin a cat for this.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Sled looks brand new never driven.Thank you guys
I just finished
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Great to see help like this, it is what makes this site great!
