TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I'm getting really tired of the huge oily mess my pl nytro makes with the bov on the bottom of intercooler. Would like to block that one off and add a better one. Any suggestions?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
yes I suggest that you fix the oil problem at the source.The oil restrictor is to large supplying the turbo
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So the powderlites turbo kits have to big of a restrictor?……where would the restrictor be? and what size restrictor should it be……..just drives me crazy the mess under the hood…….its a brand new garret turbo
HURRICANE
- Oct 17, 2007
- Prescott Ont.
the powderlites restrictor was anywhere from .035-.055 in size.Im not sure why he did that but he wouldn't change.We put a .020 restrictor inplace of it.It will be located at the engine side of the oil line
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
I will check that out……So that electronic oil return pump ok? not really any other options…thanks
HURRICANE
- Oct 17, 2007
- Prescott Ont.
The pump either works or it doesn't.ive found that when it works it does the job ok
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Is restrictor located on the bottom of the motor where the ss braided line feeding the turbo ?
