Replacement Hyfax Suggestions
Thanks again for the tip! Hyfax showed up on time and I was back and running by the weekend.
Check the worn ones, yep it was time to replace them.
Sorry, but they were way over due for replacement.
If you are in a bind, you can always use the Skidoo sliders. I tried them earlier this year to see if it would improve slider longevity...it didn't.
They fit a little loose side to side though as the opening is a couple of mm wider.
