Replacing the clutch side bearing on the drive shaft
kopenytro
St. Paul, MN
Can anyone tell me the process involved in getting the bearing and plastic collar off of the drive shaft. Is it pressed on?
The bearing needs to be replaced and I was not able to find any specifics on the replacement procedure by doing a search.
Thanks in advance.
Kope
also be sure not to lose the set screws as the new OEM bearing does not come with them!
I added a drop of Red Thread lock to the set screws when i did mine just as cheap insurance as well!
If you have a large enough pickle fork, it can be handy to put up around the drive shaft and tap on the handle of the fork to push the bearing out if it needs some help. Good luck.
