davpig
When I start my Rx1 and I put the reverse mode, the reverse work perfectly. After, when I put the sled in forward mode, the sled stay on reverse mode. I stop the engine and I start it, and it goes in forward mode...and all of that with no grinding... I check the oil level on the driving chain case, the tension of the chain. Do you have an idea of the problem?!? Thank you!!!
abj87
How is your belt tension, too high and it wont shift while running. Mine had the same problems after i replaced the belt without reseting the tension.
davpig
that is probably my problem... the belt is brand new! Thank you!
You may need to adjust the linkage on the shifter just a tad. I have had this happen several times. The upper linkage has 2 lock nuts- one on either end and then turn the shaft a quarter turn try it. If it dowsn't work go the other direction 1/2 turn.
davpig
I ajusted the linkage tomorrow like the repair manuel say... and it don't work.
